DC module deviation from STC
- karthik
21 May 2020 01:55 #8221
by karthik
DC module deviation from STC was created by karthik
I have an issue.
After simulating a model PV system in SAM, Under the losses, I am getting a huge percentage of loss under the category "DC module deviation from STC". The Loss is 51%. I do not understand how to minimize the loss or even why it's getting so high.
My Inputs are:
Photovoltaic (Detailed PV model) - Distributed Commercial Owner.
Location: phoenix_az_33.450495_-111.983688_psmv3_60_tmy
Module: CEC performance model with module database: Canadian solar Inc. CS6U-300P
Inverter: CEC database - Schneider Electric Solar Inverters USA - Inc : GT100-480 [480V]
System Design:
Inverter -1
Module array - 12 X 28
Tilt -20
Azimuth - 180
GCR - 0.943
Shading: Self-shading (non-linear) Module orientation: portrait (1 X 12); Module aspect ratio : 1.61
Losses: soiling =0 and the rest default
Can you please help me with the issue?
I have an issue.
My Inputs are:
System Design:
Inverter -1
Tilt -20
Azimuth - 180
GCR - 0.943
21 May 2020 11:11 #8222
Replied by Paul Gilman on topic DC module deviation from STC
Dear Karthik,
There is a bug in the reporting of the module loss category in SAM 2020.2.29 r1 that will be fixed in SAM 2020.2.29 r2.
This issue only affects the reporting of losses, not the electrical output values.
We are finalizing that update now and hope to release it in the next few days.
- karthik
21 May 2020 22:18 #8227
by karthik
Replied by karthik on topic DC module deviation from STC
Thanks for the information. But the output Annual energy depends on the module loss.
According to the loss diagram, my Annual energy is decreased considerably due to the module loss (more than 50%).
So, is the Annual energy is also affected because of the bug?
Can you clarify this?
Karthik.
Karthik.
22 May 2020 16:25 #8228
Hi Karthik,
The values shown in the loss diagram are calculated in a separate process from the energy output calculations, so the hourly output and accumulated monthly and annual output is not affected by the problem with the module loss calculation.
- karthik
29 May 2020 07:29 #8251
by karthik
Hallo,
Today I have tried with new version SAM 2020.2.29 r2. But I am still getting 51% module loss and annual energy 97.9 MWh.
I tried the same system in other softwares such as PVSyst and PV*SOL there I am getting annual energy 128 and 129 MWh respectively.
Can you help me with this?
Thanks & Regards,
Karthik.
Thanks & Regards,
Karthik.
29 May 2020 15:51 #8254
Hi Karthik,
A GCR of 0.943 means that the modules are very close together. For the Standard (non-linear) self shading option, SAM includes the shading loss in the "Module deviation from STC" loss category. You could reduce this loss by decreasing the GCR, or reducing the tilt angle.
Please see the documents on the PV Validation page for comparisons between SAM, PVsyst and PV*SOL:
sam.nrel.gov/photovoltaic/pv-validation.html
