DC module deviation from STC
04 Dec 2023 16:40 #12719
Replied by Paul Gilman on topic DC module deviation from STC
Hi Zeynep,
Please attach a .sam file and a copy of the weather file you are using if you would like me to help troubleshoot.
- Zeynep Celik
05 Dec 2023 19:51 - 06 Dec 2023 15:53 #12731
by Zeynep Celik
Replied by Zeynep Celik on topic DC module deviation from STC
Last edit: 06 Dec 2023 15:53 by Paul Gilman. Reason: Attach image as .png and insert into editor.
- Zeynep Celik
06 Dec 2023 06:20 #12734
by Zeynep Celik
Hi, I tried attaching some screenshots and the file but it didn't work it seems. I am attaching the file again now. Thank you!
06 Dec 2023 16:42 #12737
Hi Zeynep,
Thank you for attaching your .sam file.
This thread is about using POA irradiance as input, but your file is using the default DNI and DHI as input. In your case, the module "deviation from STC" loss is high because of shading. The partial shading model calculates shading loss as a reduction in DC output, and as the screenshot of your 3D shading scene shows, there is significant shading between modules.
You are have enabled both beam irradiance losses by time step and solar azimuth-by-altitude beam irradiance shading, which seems like you might be double-counting the effect of shading. You have also enabled self shading by enabling, although because GCR = 0.3 self shading is not having a large impact. I think I would recommend using one shading model instead of three.
- Zeynep Celik
07 Dec 2023 13:39 #12743
by Zeynep Celik
Thank you so much for pointing that out! Now I understand the difference and where I was going wrong.
