Parabolic trough freeze protection
  • Paul Gilman's Avatar
13 Nov 2012 16:56 #220 by Paul Gilman
Replied by Paul Gilman on topic Parabolic trough freeze protection
It is possible to specify a fossil fill dispatch schedule that results in the energy to the power block being greater than the energy from the solar field over a year. The extra energy comes from natural gas burned by the backup boiler.
  • vp16
  • Junior Member
  • Junior Member
14 Nov 2012 13:26 #221 by vp16
Replied by vp16 on topic Parabolic trough freeze protection
Its a system with no auxiliary back up boiler.
Also, the heat loss diagram are for the first year of operation. Correct.?
Basically, with a solar multiple of 2.5, MS PT plant, with no auxiliary boiler, it shows The Energy to the Power Block more compared to the Energy Output from Solar field. This is soemthing which I am not able to understand the logic. And the same system with a solar multiple of 3.5 has energy from power block less than energy output from the solar field.
Is it some kind of bug.? or is this justified.?
14 Nov 2012 16:48 #222 by Paul Gilman
I can't be sure what is causing that without seeing your file. Would you mind attaching it to a reply? We have fixed a few issues with the energy loss diagram in the Beta version.
