PV + Battery Parametrics Error
- Alex Stark
01 Jul 2022 10:53 #11217
by Alex Stark
Replied by Alex Stark on topic PV + Battery Parametrics Error
The attached image is taken of results via the Simulate button (not Parametrics). My total Battery bank installed capacity is 225,000 kWh, so I'm not sure how the system could output over 480,000 kW in a single hour. If this is expected, please advise.
Alex
Alex
06 Jul 2022 15:19 #11229
Replied by Paul Gilman on topic PV + Battery Parametrics Error
Hi Alex,
We found a bug with the transformer loss calculation that is causing these results. We will fix this bug for the next version of SAM: github.com/NREL/ssc/issues/847 .
Note that this only affects the value of the "electricity from battery to grid" outputs that SAM reports for reference. It does not affect the battery dispatch or other outputs. You can calculate the time series values of "electricity from battery to grid" by subtracting "electricity from system to grid" from "system power generated."
For now, any of the following options avoid this issue:
Thank you for your patience while we sorted this out.
- Set the transformer losses on the Losses input page to zero.
- Model the battery as AC connected instead of DC connected.
- Set the inverter night-time loss to zero.
- Alex Stark
06 Jul 2022 15:26 #11230
by Alex Stark
Paul,
Thanks so much for looking into this!
Best,
Alex
Best,
Alex
