64 bit SDK in windows 8
- kaiyer
23 Sep 2014 14:58 #2561
by kaiyer
64 bit SDK in windows 8 was created by kaiyer
Has anyone had success with MingGW to test the SDK with 64 bit libraries under Windows 8. The code crashes when calling ssc_data_create() in example1_pvwatts.c
thanks
Kumar Aiyer
thanks
Kumar Aiyer
- kaiyer
23 Sep 2014 17:30 #2562
by kaiyer
Replied by kaiyer on topic 64 bit SDK in windows 8
It looks like 32 bit SSC library works perfectly fine. Does the development team have a newer version of the 64bit library for windows that I could try.
- kaiyer
24 Sep 2014 15:36 #2563
by kaiyer
Can anyone in the SDK development team provide some feedback on this forum?
02 Oct 2014 16:46 #2564
Replied by Paul Gilman on topic 64 bit SDK in windows 8
We will be releasing a new version of the SDK with new libraries in a few weeks when we release the next version of SAM.
There was a problem with library names in earlier versions of the SDK that sound similar to what you are experiencing. Please check that you are using the current version of the SDK, labelled as Version 2014-1-21.
- kaiyer
19 Oct 2014 08:27 #2565
by kaiyer
Paul:
Thanks for your comment. Two users including myself independently tested the Windows-64 bit library and found the same issue.
We will wait for the new release since its just a few weeks away.
thanks
Kumar
thanks
Kumar
20 Oct 2014 10:59 #2566
Thanks Kumar. We will be sure to test the new version of the SDK on 64-bit Windows 8 before we release it.
