Details or Description of various Modules found in SSC SDKtool
  • Asif K
20 May 2024 04:47 #13176 by Asif K
I am new to using SAM and SDKtool. I am able to use a module "iph_to_lcoefcr" and run a program in visual studiio / c#. It worls perfect. Perhaps this is one of the smallest module in SDK. NOw, I am looking to use other modules shown in SDKtool. however, as of first step, I need to understand or to have some sort of descritption of all other modules.
Lets say, I am interested to use a model available in SAM  software i.e. PVWatts/ Distributed / Residential Owner, then question is it relates to which module shown in the SDKTool.
THanks
20 May 2024 15:49 #13181 by Paul Gilman
Hi Asif,
For reference, the SAM SDK is described here: sam.nrel.gov/software-development-kit-sdk .
The SSC modules are not documented, aside from whatever comments exist in the code, and the brief description in the DEFINE_MODULE_ENTRY() function at the end of the C++ file for each module, for example here for the iph_to_lcoefcr module you mention:
github.com/NREL/ssc/blob/patch/ssc/cmod_iph_to_lcoefcr.cpp
PySAM is a Python wrapper that is available as a Python package with slightly better documentation of the SSC modules:
nrel-pysam.readthedocs.io/en/main/ssc-modules.html
The PySAM documentation also lists the model configurations that are available in the SAM user interface here:
nrel-pysam.readthedocs.io/en/main/sam-configurations.html
  • Asif K
20 May 2024 23:23 #13183 by Asif K
Hi Paul
Thanks for the quick response. Appreciated !!
Could you please inform which module in SDQtool relate to following Models in SAM software:
1) Photovoltaic / Detailed PV Model / Distributed / Residential Owner2) Photovoltaic / Detailed PV Model / Distributed / No Financial Model
21 May 2024 10:24 #13185 by Paul Gilman
Hi Asif,
Detailed PV / Residential ( nrel-pysam.readthedocs.io/en/main/sam-configurations.html#detailed-pv-model-residential-owner ): belpe, pvsamv1, grid, utilityrate5, cashloan
Detailed PV/ No Financial ( nrel-pysam.readthedocs.io/en/main/sam-configurations.html#detailed-pv-model-no-financial-model ):  pvsamv1, grid
