Editing intermediate variables in PySAM
- Marcelo Fernandes
17 Nov 2020 17:48 #9011
by Marcelo Fernandes
Editing intermediate variables in PySAM was created by Marcelo Fernandes
Paul,
I have a CSP project (based on the TcstroughEmpirical module) where I am trying to edit some of the calculations done by PySAM to check for the feasibility of the changes that I am proposing. For example, I would like to be able to edit how a variable is calculated or to edit the value of a variable present in the Outputs (PySAM.TcstroughEmpirical.TcstroughEmpirical.Output) group before they are passed on to another calculation.
Here is a more concrete example where the goal is to obtain CSP power production + redirect some of the incident solar energy to another process:
Thank you in advance for your help. Let me know if you need any other details or if the question is not clear.
Best,
Marcelo
- Use a user-defined weather file
- Calculate optical parameters (sun position and angle, incidence angle modifier, efficiency, etc.)
- Calculate the amount of solar energy received by the solar field (Outputs.QsfAbs) + the amount of solar energy redirected in my project (user-defined variable)
- Send the value of Outputs.QsfAbs to the power block calculations, as it normally happens in SAM
Best,
Marcelo
19 Nov 2020 11:55 #9015
Replied by Paul Gilman on topic Editing intermediate variables in PySAM
Hi Marcelo,
When you run the SSC library through PySAM or one of the other methods provided with the SAM Software Development Kit (SDK) , you can only access the inputs to the overall library, not inputs and outputs of sub-models within the library. In your example, the power block inputs are not accessible via PySAM.
The empirical trough model and others in SAM are written in C++. The source code files associated with the empirical trough model are:
Overall model:
github.com/NREL/ssc/blob/develop/ssc/cmod_tcstrough_empirical.cpp
Solar field model:
github.com/NREL/ssc/blob/develop/tcs/sam_trough_model_type805.cpp
Thermal energy storage model:
github.com/NREL/ssc/blob/develop/tcs/sam_trough_storage_type806.cpp
Power cycle model:
github.com/NREL/ssc/blob/develop/tcs/sam_trough_plant_type807.cpp
Overall model:
Solar field model:
Power cycle model:
- Marcelo Fernandes
19 Nov 2020 13:07 #9016
Replied by Marcelo Fernandes on topic Editing intermediate variables in PySAM
Paul,
Thank you for sending each separate model, those will be really helpful in the case that I rewrite these using Python or MATLAB.
I was able to find the actual line that I would like to modify in the solar field model: github.com/NREL/ssc/blob/develop/tcs/sam_trough_model_type805.cpp#L1107 .
Would you know if I am able to modify this line in my local version of SSC? If not, is there a way to overwrite that line through PySAM or should I focus on rewriting the models you referred to in Python/MATLAB to be able to customize them?
Thanks for your time and advice,
Marcelo
Marcelo
20 Nov 2020 22:13 #9022
Hi Marcelo,
It is only possible to modify that line of code in the C++ source code. To do that, you would have to set up a build environment for your own version of SAM based on the instructions here: github.com/NREL/SAM/wiki .
It is not possible to access the code at that level through PySAM or the SAM SDK tools ( sam.nrel.gov/software-development-kit-sdk ).
Paul..
Paul..
- Marcelo Fernandes
22 Nov 2020 18:18 #9024
Thank you!
