TMY3 Files
- anindita.n.12345@gmail.com
11 Feb 2015 22:31 #2939
by anindita.n.12345@gmail.com
Replied by anindita.n.12345@gmail.com on topic TMY3 Files
I have mailed across some TMY3 files from Meteonorm that SAM (even the converter macro) is unable to use. Request to find some solution.
Anindita
Anindita
17 Feb 2015 09:21 #2940
Replied by Paul Gilman on topic TMY3 Files
Dear Anindita,
The TMY3 format files from Meteonorm that you sent have an extra column in the header. The standard TMY3 format has seven columns in the first row, but your files had eight. The third column is empty, so I deleted it and then SAM was able to read the file. I used a text editor to delete the second comma after the city name.
- okcun@yahoo.com
26 Feb 2015 08:10 #2941
by okcun@yahoo.com
Replied by okcun@yahoo.com on topic TMY3 Files
Paul,
I have used the macro for a tmy3 coming from Meteonorm 6.1 and it has created the csv perfect but still can not read the file.
- carzante
26 Mar 2016 08:45 #2942
by carzante
Replied by carzante on topic TMY3 Files
The question is:
Given a spreadsheet with 8760 hourly values of every relevant variable, but with no specific format (id est, a plain xls file)...
Is it possible to convert it into a standard SAM input file?
IS it possible to convert it into any else format (TMY3, TM2, EPW, SolarAnywhere)?
Thanks in advance.
Thanks in advance.
28 Mar 2016 10:46 #2943
The SAM CSV weather file format for solar resource data is a simple format that you can use a spreadsheet program to create. For a description of the format, see the "Weather File Formats" topic in SAM's Help system.
You could write a script or program to convert between the different file formats. SAM's Weather File Converter script converts from the file formats you list to SAM CSV, but not from SAM CSV to those formats.
