TMY3 Files
15 Jan 2015 11:04 #2933
TMY3 Files was created by Paul Gilman
Is it possible to use SAM to generate custom TMY3 files?
SAM 2014.11.24 (and later vesions) use the new SAM CSV weather file format which is a basic comma-separated text format that you can edit and create with spreadsheet software or a text editor. Older versions of SAM only read "standard" TMY3, TMY2, and EPW formats, which made it harder to work with your own data in SAM because those formats contain a lot of extra data not required by SAM, and also have stricter number formatting requirements than the SAM CSV format.
If you want to use your own data in SAM, I would recommend using the SAM CSV format.
See SAM's Help system for a description of the SAM CSV format: Weather Data, Weather File Formats.
You can use SAM's Weather File Converter macro to convert files from those standard formats to SAM CSV.
- csmichels
22 Jan 2015 07:56 #2934
by csmichels
Replied by csmichels on topic TMY3 Files
I've manually built a SAM CSV weather data file and it works perfectly (for Flat Plate PV, at least). But where I could find this macro to convert my customized TMY3 files (built using old SAM's TMY3 creator) to the new SAM CSV format?
Best Regards,
Sebastián
Best Regards,
Sebastián
22 Jan 2015 11:59 #2935
Replied by Paul Gilman on topic TMY3 Files
Dear Sebastián,
To find the macro, first create or open a SAM project file. In the lower left corner of the window, under the "Simulate" button, click "Macros." On the Macros page, click "Weather File Converter" and follow the instructions.
- anindita.n.12345@gmail.com
04 Feb 2015 02:24 #2936
by anindita.n.12345@gmail.com
Replied by anindita.n.12345@gmail.com on topic TMY3 Files
i have tried the macro with both TMY3 as well as TMY2 files from Meteonorm 7. it could not execute the tmy3 file, whereas it generated an erroneous file with tmy2. both cases, the macro fails to give the desired results.
04 Feb 2015 10:11 #2937
The Weather File Converter macro is designed to work with the "standard" files from the National Solar Radiation Database (NSRDB). We have not tested it with TMY3 format files from other sources like Meteonorm.
Would you mind emailing me examples of TMY2 and TMY3 format files from Meteonorm that we could use for testing? You can email them to sam dot support at nrel dot gov.
- clarknd
05 Feb 2015 12:28 #2938
by clarknd
Replied by clarknd on topic TMY3 Files
I found this same issue with CPR's data as well. Little things like having blanks where zeros should be seem to break everything. Hopefully NREL takes a leadership position and has a discussion with all stakeholders on this discussion to move from a "standard" to a standard.
