Solar data - program does not run
  • Verlemm
21 Jun 2014 01:45 #2391 by Verlemm
Replied by Verlemm on topic Solar data - program does not run
Well, this is getting confused.
Why should I check the weather data, if it actually is given in the list from SAM, so it should be correct? For example, I use the data
MI Muskegon.tm2
and it does not work.
I installed again, but its the same.
Regards
  • Verlemm
21 Jun 2014 05:33 #2392 by Verlemm
Well, now I tried the same SAM in Windows PC from a friend. It works.
Conclusion: all these problems are created by the Linux.
Anyway thank you for your help.
