variables missing in parametric trough simulation
  • solarjoe
20 Nov 2013 00:02 #1968 by solarjoe
I just ran a parametric trough simulation (empirical) and
found some of the output variables that are available
after a single case run (Base case") missing.
Tables - Choose Simulation - Parametric
e.g.
Single Values - Solar Field ($/W)
Single Values - Solar Field (W)
but also many others.
Is there a reason for this behaviour?
Btw, any news on the CSP SDK?
Kind regards,
Joe
20 Nov 2013 15:19 #1969 by Paul Gilman
Replied by Paul Gilman on topic variables missing in parametric trough simulation
Dear Joe,
I could not replicate that issue. When I run a parametric simulation with the empirical trough model, the Solar Field ($/W) and Solar Field ($) output variables are both available in the Single Values table, both for the Base Case simulation and for the Parametric Set 1 simulation. I tested this in both SAM 2013.9.20 and SAM 2013.1.15. Could you attach a .zsam file to your original post that illustrates this behavior?
We're porting the CSP model code from FORTRAN to C++ now, so those should be available in the SDK with the 2014 version of SAM, which we plan to release in about a year (Fall 2014).
  • solarjoe
21 Nov 2013 01:03 #1970 by solarjoe
I added three files to the original posts, two images and a zsam file.
Kind regards,
Joe
21 Nov 2013 10:16 #1971 by Paul Gilman
Hi Joe,
Thanks for attaching those files. Now I do see what you mean.
The reason the cost-related values to not appear under Single Values with the parametric results is that you did a parametric study on the Solar Field Cost per m2 value. If you were to do a parametric study on a non-cost input variable like Location, then you would see the cost variables in the results (and they would be the same for each parametric run).
The reason for that has to do with the way SAM runs simulations and stores values of results. The Solar Field ($) and Solar Field ($/W) and other costs are, technically speaking, not results of the financial model. They are values that SAM calculates from values on input pages and stores separately as it displays the user interface after running simulations. When you run parametric simulations, it does not calculate these special results for each parametric run.
  • solarjoe
25 Nov 2013 00:13 #1972 by solarjoe
thanks for the clarification.
I personally prefere SamUL for complex parametric runs anyway.
And of course Matlab as soon as the CSP SDK is established. :)
Kind regards,
Joe
05 Feb 2014 10:31 #1973 by Paul Gilman
Hi Joe,
The CSP modules are now available in the SDK. See sam.nrel.gov/node/68918 .
