Data load
- efundem.ashu@pepperdine.edu
                17 Dec 2024 11:33         -  17 Dec 2024 15:03        #13705
        by efundem.ashu@pepperdine.edu
        Data load was created by efundem.ashu@pepperdine.edu
I am unable to load wave energy data (csv file and .nc files) from my PC into SAM
        Last edit: 17 Dec 2024 15:03  by efundem.ashu@pepperdine.edu.
                17 Dec 2024 12:29                #13707
        Replied by Paul Gilman on topic Data load
Please attach an example of a .csv file you are trying use if you would like me to help troubleshoot.
                17 Dec 2024 15:18                #13711
Thank you for sharing your files.
The .nc file is a binary file that SAM does not recognize.
The .csv file appears to contain time series data. I can't tell from the column headings exactly what the data is.
To use the data with SAM's Marine Energy Wave model, you will have to reformat the data into the format described under "Time Series Format for Wave Energy Resource Data" in the Help topic "CSV Format for Marine Energy:" samrepo.nrelcloud.org/help/weather_format_csv_marine_energy.html .
                17 Dec 2024 15:48                #13712
        Replied by efundem.ashu@pepperdine.edu on topic Data load
        Thanks. Will this be the link to the converter?
                17 Dec 2024 15:56                #13713
The link in my previous post is to the SAM Help topic that describes the file formats for wave resource data that SAM's Marine Energy Wave model requires. You will need to manually convert your data to match the format description.
                17 Dec 2024 16:30                #13714
        Thanks.  Besides that is there a data size limit for SAM?
