Results in tower CSP
26 Jul 2021 09:18 #9872
Replied by Paul Gilman on topic Results in tower CSP
Hi Francisco,
SAM records the curtailed energy. If you specify a curtailment compensation rate in $/kWh on the Revenue page (under "Curtailment Payments"), then SAM treats this curtailed energy as a source of revenue for the cash flow model.
You can see the amount of curtailed energy on an annual basis using the "curtailed energy" output variable. You can also compare the "system power before grid curtailment" and "system power generated" time series variables to see the hourly or subhourly curtailment.
Please note that the curtailment variables are reported using kW/kWh in some places and MW/MWh in others, so pay attention to the units.
- Maria
11 Aug 2021 11:09 #9924
by Maria
Replied by Maria on topic Results in tower CSP
I was reviewing this example that Francisco attached. But a question arose. How could it be explained that at certain times the generation is negative? (reference image attached). According to the dispatch strategy that Francisco wrote, that hour is where the turbine works at low power. When the turbine works at minimum power, there is a negative production. Could it be that there the parasitic consumptions are greater than the generation? Could that be the explanation? In that case, perhaps it would be to ensure a minimum fraction that at least covers parasitic consumption.
I would appreciate your opinion on this, please.
Kind regards,
Maria
Kind regards,
Maria
16 Aug 2021 15:14 #9944
Hi Maria,
Time steps (in this case hours) with negative generation are time steps when the plant parasitic loads are greater than the power generated by the system.
