Confusion Regarding Irradiance Calculation
02 Jul 2021 10:42 #9770
Replied by Paul Gilman on topic Confusion Regarding Irradiance Calculation
Yes.
You may want to refer to the original papers for these equations. You can find them listed in the manual's References section: De Soto (2004a), De Soto (2004b), and Duffie and Beckman (2013).
- David
06 Jul 2021 18:14 #9789
by David
Replied by David on topic Confusion Regarding Irradiance Calculation
Where can I find the value of 'a' in eqn 4.2 ?
07 Jul 2021 14:06 #9802
Hi David,
Maybe the original source code will help:
github.com/NREL/ssc/blob/37637c9d492e4e2e79adbf43ccb9afad7abb4ddb/shared/lib_irradproc.cpp#L681
Equation 4.2 is a representation of Line 693.
- David
07 Jul 2021 14:38 #9804
by David
Why does the source code have different formulas than what is shown in the document ?
09 Jul 2021 16:10 #9814
Hi David,
The equations in the source code are adapted from the equations in the original model descriptions and may include modifications to make them work in the context of the computer model.
- Michel
29 Aug 2021 11:42 #10016
by Michel
Replied by Michel on topic Confusion Regarding Irradiance Calculation
Question related to this stream:
Eq. 9.11 in the tech manual calculates the sky diffuse shading factor. It is a function with 4 variables: array tilt ( betas), length of side of the array (
, Distance between arrays ( R) and number of rows. .
frac calculated manually. with tilt= 40 deg, B=4, R=12.5 nrows=16 gives frac= 0.981326 (a constant not function of the irradiance)
frac calculated with the same parameters by SAM shown in 'data table' / 'lifetime hourly data' / "Subarray 1 Self-shading non-linear sky diffuse irradiance factor | (frac)" = 0.951244 ( also constant over the year)
Why is the value calculated by SAM different from the value calculated with Eq. 9.11 ?
frac equation equivalent attached.
, Distance between arrays ( R) and number of rows. .frac calculated manually. with tilt= 40 deg, B=4, R=12.5 nrows=16 gives frac= 0.981326 (a constant not function of the irradiance)
