How to calculate Diffuse Horizontal Irradiance?
- Jack Simpson
09 Dec 2020 03:59 #9077
by Jack Simpson
How to calculate Diffuse Horizontal Irradiance? was created by Jack Simpson
I have been preparing solar data from the Australian Bureau of Meteorology - they provide the GHI and DNI parts of the equation below, but not the DHI which I need to simulate a solar panel in SAM.
Global Horizontal (GHI) = Direct Normal (DNI) X cos(θ) + Diffuse Horizontal (DHI)
Does anyone understand where the data comes from for the cosine response to incident angle section of the equation? I think that if I can figure that part out I can use that to solve for the DHI part of the equation. Thanks so much for the help.
09 Dec 2020 09:46 #9079
Replied by Paul Gilman on topic How to calculate Diffuse Horizontal Irradiance?
Hi Jack,
SAM's Detailed PV model accepts a weather file with any combination of two of DHI, DNI, or GHI, so you should be able to use the weather data without calculating the DHI. See my reply to the following post for instructions:
sam.nrel.gov/forum/forum-general/3184
For a fixed array with no tracking, theta is equal the array tilt angle input.
- Jack Simpson
14 Dec 2020 01:42 #9108
by Jack Simpson
Replied by Jack Simpson on topic How to calculate Diffuse Horizontal Irradiance?
Thanks so much for the help!
