How to increase sub arrays to more than 4 in SAM tool
  • Darren
12 Aug 2020 15:07 - 12 Aug 2020 17:39 #8549 by Darren
Good day,
I am currently working on a model and we may require more than 4 sub arrays in the shading screen. Please advise if this can be increased in the tool?
Last edit: 12 Aug 2020 17:39 by Paul Gilman.
12 Aug 2020 17:43 - 18 May 2023 09:35 #8556 by Paul Gilman
Hi Darren,
For SAM's Detailed Photovoltaic model, each case in SAM supports up to four subarrays, so it is not possible to define shading scenarios for more than four subarrays.
Depending on the system you are modeling, you may be able to use the Combine Cases macro to represent the system, as described in this post: sam.nrel.gov/forum/forum-general/1540 .
UPDATE: As of SAM 2021.12.02, the Combine Cases macro is replaced by the Calculate generation profiles and nameplate capacity from open cases option on the Power Plant page for the Generic System model and Generic Battery model. See the SAM YouTube channel for a short tutorial .
The image you posted did not upload properly. If you would like to include it in a reply, please attach it as a file using the Attachments button (you can then insert it into your message) rather than pasting it into the editor.
Last edit: 18 May 2023 09:35 by Paul Gilman.
