Text Not Displaying Properly in Linux
- Matt Dean
10 Nov 2019 08:05 #7780
by Matt Dean
Text Not Displaying Properly in Linux was created by Matt Dean
In SAM 2018.11.11, on Ubuntu 18.04 , the text at the bottom of the Location and Resource page is illegible.
Screenshot attached.
10 Nov 2019 09:48 #7781
Replied by Paul Gilman on topic Text Not Displaying Properly in Linux
Hi Matt,
Thank you for pointing that out. We'll try to fix it for the next version:
github.com/NREL/SAM/issues/153
- Matt Dean
17 Nov 2019 18:27 #7795
by Matt Dean
Replied by Matt Dean on topic Text Not Displaying Properly in Linux
If I launch SAM from a terminal, I get the following:
(sam.bin:21594): Gtk-CRITICAL **: 19:17:19.222: IA__gtk_widget_set_size_request: assertion 'width >= -1' failed
- Aaron Sahm
09 Dec 2020 14:01 #9082
by Aaron Sahm
Replied by Aaron Sahm on topic Text Not Displaying Properly in Linux
I just installed the latest version: sam-linux-2020-11-29 on Linux Mint and so far the program seems to work. The only issue is the text and spacing of things is a little wonky. I get several of the same messages as Matt Dean:
(sam.bin:2889): Gtk-CRITICAL **: 12:26:05.826: IA__gtk_widget_set_size_request: assertion 'height >= -1' failed
(sam.bin:2889): Gtk-CRITICAL **: 12:26:05.828: IA__gtk_widget_set_size_request: assertion 'height >= -1' failed
(sam.bin:2889): Gtk-CRITICAL **: 12:28:01.861: IA__gtk_range_set_range: assertion 'min < max' failed
Thanks for all the great work you guys do. If there's anything you'd like me to try out let me know.
09 Dec 2020 17:03 - 09 Dec 2020 17:03 #9086
Hi Aaron,
This is an ongoing issue. We are doing our best to lay out user interface elements so they work across Windows, Mac, and Linux. Please let me know if you find any places where the user interface is unreadable so we can at least fix those.
The Gtk-CRITICAL errors should not prevent SAM from running, but they are annoying. Sorry we don't have the resources to address them for now.
Last edit: 09 Dec 2020 17:03 by Paul Gilman.
- Aaron Sahm
09 Dec 2020 17:14 #9087
by Aaron Sahm
Thanks for the quick response. In my case it might be related to the font sizes I have set for the OS. I have them set to be a little bigger than normal since I have the desktop connected to a HDTV. That is probably not very common. It's still readable, just needs some sizing adjustments. Thanks again.
