How to convert WIND Toolkit into SRW file
- Michael Starrett
23 Oct 2019 10:27 #7753
by Michael Starrett
How to convert WIND Toolkit into SRW file was created by Michael Starrett
I was having trouble getting SAM to download the wind files for other locations and made a post, here:
sam.nrel.gov/forum/forum-general/2843-how-to-download-srw-files-outside-of-sam.html
Where I was advised that I could create my own SRW files.
I tried to make a follow up post but am not seeing it now - not sure what went wrong - but my question is: How do I download WIND Toolkit files with the necessary info to convert to SRW?
The SRW are delineated on hub height, with columns of [Temperature Pressure Direction Speed] for each hub height 50, 80, 110, & 140m.
When I download data from the WIND Prospector Website, I do get these columns (among others), EXCEPT that I do not get the hub height, and I do not know what hub height the data represents.
I still haven't been able to get SAM to download the SRW files so I am hoping to make this work. Any help appreciated!
24 Oct 2019 17:33 #7755
Replied by Paul Gilman on topic How to convert WIND Toolkit into SRW file
Hi Michael,
From what I can gather from Table 1 in this document (provided as a link from the Wind Prospector website), the data from the Wind Prospector is at 100 m:
www.nrel.gov/docs/fy15osti/61740.pdf
Let me know if you discover anything different.
- Michael Starrett
12 Nov 2019 11:28 #7785
by Michael Starrett
Replied by Michael Starrett on topic How to convert WIND Toolkit into SRW file
Many thanks! I found that I was able to use that data to create an SRW file for each location at the 100m hub height.
I am hopeful that one day I'll be able to get the 80m data from the NREL SAM tool, but I understand that this is an API issue.
Thank you again, Paul!
- Olukunle
29 Jun 2020 08:03 #8365
by Olukunle
Replied by Olukunle on topic How to convert WIND Toolkit into SRW file
Actually the Wind Speed, Direction, Temperature at 80m is available via the API. Make sure that you do not set attributes then this way you can get all of the data referenced by Paul in the link here:
- lia
01 Feb 2021 14:18 #9252
by lia
Replied by lia on topic How to convert WIND Toolkit into SRW file
Can I obtain the data for 80m for my location in the uk?
02 Feb 2021 10:35 #9253
I do not know of a source of wind resource data for the UK. Please let us know if you find anything.
