SAM HTF library
- sebastian
07 Aug 2012 12:07 #754
by sebastian
SAM HTF library was created by sebastian
I was looking after the physico-chemical properties of the Therminol VP-1. They should be at the HTF library in the SAM guide but I can´t find them.
Does anyone know where could I find that properties?? Or they are only available from the manufacturers??
Thanks a lot for your help.
Regards.
Regards.
08 Aug 2012 11:31 #755
Replied by Paul Gilman on topic SAM HTF library
Please see the workbook attached to the following post for a list of properties of Therminol VP-1 and other fluids:
sam.nrel.gov/content/heat-transfer-fluid-properties
- Mithras CSP
10 Aug 2012 06:38 #756
by Mithras CSP
Replied by Mithras CSP on topic SAM HTF library
17 Sep 2012 15:35 #757
Hi Marc,
Thank you for the suggestion to add the heat transfer fluids. Therminol 66 and 59 will be in the Fall 2012 version of SAM. We plan to release a Beta test version at the end of September, so you can see the new fluids in that version before the official release.
