Gemasolar Simulation
  • jqcano
06 Apr 2019 03:35 #6737 by jqcano
Gemasolar Simulation was created by jqcano
Hi!
I'm having some problems when simulating CSP Gemasolar (Seville, Spain) on SAM 2018. I'm using the same data used in a older version in this website (for SAM 2013 or so), but i'm not receiving the same solution. For example, annual energy production results in "-3e12", what's just stupid (I'll attach a screen capture of main results).
Probably I'm making some units mistakes, but there's a lot of parametres to control, and I'm not finding the problem.
Could anybody help me? Any advise or possible solution will be welcomed! :)
Thank you very much!
08 Apr 2019 12:19 #6738 by Paul Gilman
Replied by Paul Gilman on topic Gemasolar Simulation
Could you attach a copy of your .sam file to your post above (click Edit to add an attachment) along with the weather file you are using?
15 Apr 2019 15:45 - 28 Jun 2019 09:34 #6739 by Paul Gilman
Dear Javier,
Thank you for attaching the file. I could not quickly find the cause of the negative outputs.
As you know, the Gemasolar analysis was done using an old version of SAM, and we have made numerous improvements to SAM's Molten Salt Power Tower model since then.
Have you downloaded the old .zsam file from the Case Studies and Validation page and opened it in SAM 2014.1.14? (You can download the old version from the "Legacy Versions" list on the Download page. Then, you can run the two versions of SAM side-by-side to compare the inputs.
Last edit: 28 Jun 2019 09:34 by Paul Gilman.
22 Apr 2019 11:01 - 28 Jun 2019 09:34 #6740 by Paul Gilman
Dear Javier,
We have posted a newly published article that discusses a SAM simulation of the Gemasolar plant. The authors graciously agreed to share a SAM file developed in SAM 2017.9.5 that should also work in later versions of SAM. You can find a link to the article and SAM file on theĀ  Case Studies and Validation page.
