Modeling DC Optimizers with Multiple MPPT Feature
10 Jun 2019 15:02 #7450
Replied by Paul Gilman on topic Modeling DC Optimizers with Multiple MPPT Feature
Hi Wink,
The "Inverter Datasheet" and "Inverter CEC Database" options on the Inverter input page are separate models, so the inputs for the two options do not match. For the Inverter Datasheet option, the idea is that you would find the input parameter values on the inverter manufacturer's datasheet.
You shouldn't need to modify the CEC Inverter.csv file. SAM reads the data from that file to populate the list of inverters on the Inverter CEC Database option. I would not recommend editing that spreadsheet unless you know what you are doing. It contains parameters that we generate from the inverter test data provided in the source data for that list at www.gosolarcalifornia.ca.gov/equipment/inverters.php .
My suggestion was that you create your own inverter using the Inverter Datasheet option with parameter values from the manufacturer datasheet so that you can modify the MPPT minimum and maximum voltage ratings.
- Wink Saville
10 Jun 2019 16:43 #7453
by Wink Saville
Replied by Wink Saville on topic Modeling DC Optimizers with Multiple MPPT Feature
Thanks Paul!
I'm wondering why microinverters and DC Optimizerers aren't supported more directly?
Besides this thriead I also found this doc from this 2015 post and this post from 2017 with an update by you this year , but they feel like round-about solutions. I recently asked for bids and all bids were either microinverters or optimizers, so it would seem directly supporting them would be helpful.
-- Wink
-- Wink
