Cooling tower water use results_reply
  • FrankNam
05 Sep 2018 07:38 #6430 by FrankNam
Cooling tower water use results_reply was created by FrankNam
Hi Paul
Thanks for the support.
From the Equation 3.25 of the Physical Trough Reference Manual, could you please indicate which value is being reported in the time-series results of SAM as "Hourly Data: Cycle cooling water mass flow rate - makeup (kg/hr)",i.e. is it mdotwater or mdotcw?:
mdotevap = qdotrej/hevap
mdotdrift = fdrift mdotcw
mdotctbd = fctbd mdotcw
mdotwater = mdotevap +mdotdrift +mdotctbd
Furthermore, where in the code on github is mirror cleaning water consumption accounted for? If this is not reflected in the github code, does SAM account for this and where are the results accessible?
Thank you once again
05 Sep 2018 12:52 #6431 by Paul Gilman
Replied by Paul Gilman on topic Cooling tower water use results_reply
Please see my reply to this post:
sam.nrel.gov/node/80080
