questios photovoltaic commercial
- Rei
04 May 2017 13:20 #5418
by Rei
Replied by Rei on topic questios photovoltaic commercial
Thank you very mutch Paul, Your answers was very usefull. Can you check the attached file to see if it is well made?
Best
Rei
Best
Rei
08 May 2017 15:07 #5419
Replied by Paul Gilman on topic questios photovoltaic commercial
Dear Rei,
The latest version of your file looks good, and will result in a reasonable estimate of the effect of shading on the array output.
However, it does not make use of the 3D shade calculator's partial shading calculations, which work with crystalline Silicon modules, and can more accurately estimate the effect of partial shading of the array for modules with diodes. To make use of those calculations, you should replace each active surface in the 3D shading scene with a set of surfaces for each string in the subarray.
For example, for your file, on the System Design page in SAM, you can see that Subarray 1 has 5 strings, Subarray 2 has 4 strings, and Subarray 3 has 5 strings. To model that in the 3D shade calculator, you could replace the active surface for Subarray 1 with 5 smaller active surfaces. Assign the number 1 to the Subarray property for all five of those active surfaces, and assign the numbers 1-5 to the String property for each of those active surfaces. Similarly, create 4 active surfaces for Subarray 2, and 5 active surfaces for Subarray 3.
After you make those changes in the scene, the 3D shade calculator will calculate a set of shading losses for each string, and automatically assign them to each subarray on the Shading and Snow input page.
