Capacity factor is zero and Payback period is NaN
  • cspchathu
25 Oct 2016 12:32 #4859 by cspchathu
Hi all,
I am new for SAM. I am doing a study on CSP feasibility for Sri Lanka. I got the results and my file is attached herewith. Result shows that simple pay back is NaN and capacity factor is 0. I think that I have done some thing wrong when I entered inputs. Please help me on this.
Also my effort is to find a tariff rate which can be feasible in Sri Lanka. Please give me a guide to do that. And if you have any idea, What will be the best way to to do a feasibility on CSP in here?
Also, If I want simulate 10 MW,plant for a particular place, how can I do that? If I change gross net output and net conversion factor in power cycle tab, is that correct?
25 Oct 2016 15:20 #4860 by Paul Gilman
Replied by Paul Gilman on topic Capacity factor is zero and Payback period is NaN
The zero capacity factor indicates that the system is not generating any power. I see that you set the solar field aperture area to 13,000 square meters, which is not big enough to supply heat to the 11 MW power cycle. For a system with no storage, you can try a solar multiple of 1 instead of specifying the field area, and let SAM determine how big of a field you need. In my test, a solar mulitple of 1 resulted in a field area of about 45,000 m2 and a system capacity factor of 13%, which is still low, but perhaps realistic given the low solar resource. Increasing the solar multiple will increase the capacity factor (and costs).
SAM's commercial financial model is for a renewable energy system that reduces a building or facility's annual electric bill and requires information about retail electricity rates to calculate the bill savings. Is that the type of project you are trying to model? The PPA single owner model is appropriate for a power generation project.
I am not aware of where to find data for Sri Lanka retail electricity rates.
Yes, you define the system's nameplate capacity on the Power Cycle page.
You may be interested in the SAM webinar on modeling parabolic trough systems, which you can find on the Webinars page of this website, under "2014 Webinars:"
sam.nrel.gov/webinars
  • cspchathu
27 Oct 2016 09:53 #4861 by cspchathu
Dear Mr.paul,
As you advised, I selected option 01 in solar field parameters instead of inserting land area. Now I can can get 20.4% capacity factor. still my pay back is NaN. Is there any wrong in my inputs.
  • cspchathu
27 Oct 2016 13:32 #4862 by cspchathu
Revised file based on your reply is attached here with.
  • burakomersaracoglu
28 Oct 2016 03:51 #4863 by burakomersaracoglu
Replied by burakomersaracoglu on topic Capacity factor is zero and Payback period is NaN
Hello;
According to your sentence "my effort is to find a tariff rate which can be feasible in Sri Lanka" I think you should work with "Break-Even Analysis". You have three important issues 1-) Plant design, 2-) Cost Estimations 3-) Sale Price Estimations. You can easily work on SAM for plant design. For cost estimations, you can work on SAM but you need to estimate the costs in Sri Lanka. You have many different approaches here too. You can apply fuzzy models, grey models, probabilistic models, etc. You should work on some cost work breakdown structures for Sri Lanka too. May be you should study a little bit accounting issues too. For the sale price you can make simulations on SAM. You will get some financial performance measures such as rate of return and net present worth on SAM for different cost and sale price values. Afterwards when you draw your graphs for "Break-Even Analysis" you will get the "tariff rate which can be feasible in Sri Lanka". The minimum tariff rate, you should take into account and evaluate. I can help you on some approaches during your study, if you have been preparing your thesis or manuscript (only giving some guiding ideas). Some references for "Break-Even Analysis"
www.investopedia.com/terms/b/breakevenanalysis.asp
en.wikipedia.org/wiki/Break-even_(economics)
articles.bplans.com/break-even-analysis/
www.thebalance.com/how-to-do-a-breakeven-analysis-1200834
www.inc.com/guides/2010/12/how-to-perform-a-break-even-analysis.html
hbr.org/2014/07/a-quick-guide-to-breakeven-analysis
Good luck
Have a nice day
Burak Omer Saracoglu
  • cspchathu
29 Oct 2016 05:39 #4864 by cspchathu
Thank you Mr.Saracoglu for your valuable inputs. I'l try as u explained.
