SDK and Python 3, errors and improvements 2
- solarjoe
15 Jan 2015 05:23 #2927
by solarjoe
SDK and Python 3, errors and improvements 2 was created by solarjoe
Hello Paul,
I downloaded the new release of the SDK but the Python files did not change since the release
mid of December. Only the file ssc.pyc was added.
I attached my script to this new thread because I could not attach it to the other one.
There was a brower error message:
An AJAX HTTP request terminated abnormally.
Debugging information follows.
Path: /file/ajax/upload/und/form-DuZKA4pRL0p8w4i30-DUNxKR8csYRsLETV7LQhq576w
StatusText: n/a
ResponseText: The specified URL cannot be found.
ReadyState: undefined
About the Python script, the UTF-8 error is related to the function info_label().
return t.decode('utf-8')
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x91 in position 19: invalid start byte
You can also check the other changes to convert from Python 2 to 3, maybe you have better
ideas.
Kind regards,
Joe
StatusText: n/a
ideas.
Kind regards,
Joe
- solarjoe
10 Feb 2015 01:19 #2928
by solarjoe
Replied by solarjoe on topic SDK and Python 3, errors and improvements 2
Hello Paul,
any news on what might cause the UnicodeDecodeError in Python 3?
Kind regards,
Joe
Kind regards,
Joe
10 Feb 2015 10:37 #2929
Replied by Paul Gilman on topic SDK and Python 3, errors and improvements 2
Sorry for the delay, Joe. Thank you for posting your Python example. We're investigating the unicode issue now. I just posted an update to the SDK for SAM 2015.1.30.
17 Feb 2015 16:37 #2930
Hi Joe,
We've finally tracked down the cause of the unicode error and have a fix. The error is caused by C++ code in the SSC module for the HCPV module that uses a single quote in one of the output variable labels. The solution for the Python wrapper is to modify the definition of
in sscapi.py.
Old:
self.pdll.ssc_info_label.restype = c_char_p
return self.pdll.ssc_info_label( c_void_p(p_inf) )
New:
Here is a link to a version of sscapi.py with the correction:
sscapy-3-4-2.py.txt ( PY 104 KB ). You'll have to remove the .txt extension after you download the file.
We will include this file in the next version of the SDK
Best regards
info_label()
Old:
def info_label( self, p_inf ):
New:
def info_label( self, p_inf ):<br />
self.pdll.ssc_info_label.restype = c_char_p<br />
t = self.pdll.ssc_info_label( c_void_p(p_inf) )<br />
return t.decode('utf-8', 'ignore')
Best regards
- sjschneider
11 Oct 2016 12:47 #2931
by sjschneider
Replied by sjschneider on topic SDK and Python 3, errors and improvements 2
I've ported SAM's Python 2 API to Python 3 and set it up as a Python module: py3samsdk . It is compatible with the latest March 14, 2016 release. I've set up some unit tests, but it has not undergone extensive platform testing, etc. Please feel free to use and contribute!
- Stephen
- Stephen
- solarjoe
17 Jan 2017 05:50 #2932
by solarjoe
Hello Paul,
will you deploy py3samsdk with the SAM SDK in the future?
Joe
Joe
