Creating a function to monitor PV module output as a function of cell efficiency
- Michael Caballero
01 Mar 2025 16:01 #13909
by Michael Caballero
Replied by Michael Caballero on topic Creating a function to monitor PV module output as a function of cell efficiency
This is very helpful thank you. I believe I see where the equations are:
dcpwr += dcpwr*(Gamma/100.0)*(TcellC - 25.0);
where the initial dcpwr is:
dcpwr = dceff*(input.poaIrr)*Area;
this corresponds to simple efficiency model equation in the tech guide:
Pmp = GηmAm (γmp,ref/100) (Tc −25)
So it looks like my model is in line. The only difference I made is to calculate an hourly 'effective' efficiency based on panels nominal efficiency,the ambient and cell temp and irradiance at each hour. In ampl code it looks like this:eff_val{t in PV_TYPES, h in HOURS} =pv_eff_ref[t] * (1 + temperature_coeff[t]*(temperature[h] - reference_temp))* (I[h] / reference_irradiance);the hourly DC output is then: (eff_val*Area of the panel*Number of panels*Irradiance)/1000
My hourly DC values seem to be longer than SAMs which makes some sense but I think the discrepancy is more than it should be. The other concern I have is that I'm not using the solar data correctly. How does the simple efficiency model use the solar data to determine hourly solar resource? Right now I'm just using DHI values from tmy data file for medly Florida, along with the temperature. Should I be incorporating the other solar values or doing a calculation for more accurate solar resource data?
Thanks!
Michael
Thanks!
Michael
06 Mar 2025 09:17 #13927
Replied by Paul Gilman on topic Creating a function to monitor PV module output as a function of cell efficiency
Hi Michael,
SAM calculates the plane-of-array (POA) irradiance based on the irradiance data in the weather file (DNI and DHI by default), sun position, and array orientation. These equations are described in Chapter 6 of the SAM PV techncial manual I referenced above.
The source code for these calculations is in lib_irradproc.cpp: github.com/NREL/ssc/blob/patch/shared/lib_irradproc.cpp
- Michael Caballero
12 Mar 2025 15:42 #13947
Is there a way I can extract that POA irradiance from SAM after running a simulation? I uploaded data for medley FL and ran the simple efficiency module model and am reviewing the hourly system power generated:kW-0.150056-0.150056-0.150056-0.150056-0.150056-0.150056-0.15005652.3858338.227633.607206.791796.574
If I could get the hourly POA data that SAM is using I could upload it to my model to make sure I'm 1 to 1 in my solar calculations, at least as far as solar resource.
Best,
Michael
Best,
Michael
13 Mar 2025 11:46 #13952
Hi Michael,
I think 'poa_front' is the output you are looking for:
nrel-pysam.readthedocs.io/en/main/modules/Pvsamv1.html#PySAM.Pvsamv1.Pvsamv1.Outputs.poa_front
