Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM
13 Nov 2024 17:16 - 04 Dec 2024 17:42 #13594
Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM was created by Paul Gilman
When you use SAM's
code generator
with the "PySAM JSON" option, it generates two JSON files: One with the case name, such as "untitled.json" and one with the case name and "_pvsamv1" appended, such as "untilted_pvsamv1.json". The latter file uses 'sixpar_' as required by PySAM, and indicated in the documentation of the
Pvsamv1 user-specified module parameters variables
Here's a Python script you can use to test that. First, in SAM, create a default Detailed PV / No Financial case, and then go to the Module page and choose the CEC Performance Model with User Entered Specifications option from the blue list at the top of the page. Then, on the Case menu, click Generate code, PySAM JSON.
import json
import PySAM.Pvsamv1 as PV
# create a new pvsamv1 model
pv = PV.new()
# assign inputs from JSON generated by SAM
with open("untitled_pvsamv1.json", "r") as file:
data = json.load(file)
# loop through each key-value pair
for k, v in data.items():
if 'adjust_' in k: # workaround for https://github.com/NREL/pysam/issues/164
k = k.replace('adjust_', '')
if k != "number_inputs":
pv.value(k, v)
# print inputs for user-specified module parameters option to verify "sixpar" in variable names
print(pv.CECPerformanceModelWithUserEnteredSpecifications.export())
# run pvsamv1 for no bifacial
pv.execute()
# print some results
print(pv.value("annual_dc_net"))
print(pv.value("annual_ac_gross"))
# change user-specified module bifacial parameter
pv.value("sixpar_is_bifacial", 1)
# print inputs to confirm bifacial mode is enabled
# run pvsamv1 for bifacial
pv.execute()
# print results -- should be higher than non-bifacial
Last edit: 04 Dec 2024 17:42 by Paul Gilman.
- Jesús Polo
04 Dec 2024 08:10 #13631
by Jesús Polo
Replied by Jesús Polo on topic Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM
I get an error in the part pv.value(k,v),
The error is: 'utf-8' codec can't decode byte 0xff in position 42: invalid start byte
In theory I can create a pv model using pvsamv1.default() and I will have all the parameters by default, annd then I can rewirte some of the parameters from the json file I create from the SAM gui, but I always get the error I mentioned
Any idea of what to do?
Thanks a lot
Jesus
Thanks a lot
Jesus
04 Dec 2024 17:45 #13634
Replied by Paul Gilman on topic Pvsamv1 CEC Performance Model with User Entered Specifications Option and PySAM
Hi Jesus,
Could you attach the files you are using for your test (preferrably a minimal code example)? You could compress the .py and .json file into a .zip file to make it easier for me to try to replicate this issue.
- Jesús Polo
05 Dec 2024 02:35 #13637
by Jesús Polo
05 Dec 2024 10:22 #13639
Hi Jesus,
Thank you for attaching the files. Could you also send the .sam file you used to generate the JSON input file?
The UTF-8 Codec error is caused by PySAM attempting to read a variable that it does not recognize. We hope to fix this so that it generates a more meaningful error message.
You can find the variable that is causing the error by adding 'print(k)' in the loop that sets the module inputs:
From the discussion above, we know that the variable names starting with "6par" are not valid PySAM variable names. We can fix that by replacing "6par" with "sixpar". There is a separate issue with variable names that start with "adjust." To fix those issues:
There are some additional variables causing problems in your JSON file, so please share the .sam file that you used to generate the JSON if you would like me to help troubleshoot.
for k, v in pv_inputs.items():
print(k)
if k != 'number_inputs':
pv_model.value(k, v)
print(k)
if '6par' in k:
k = k.replace('6par','sixpar')
if 'adjust_' in k:
k = k.replace('adjust_', '') # fix from https://github.com/NREL/pysam/issues/164
- Jesús Polo
08 Dec 2024 23:51 #13664
by Jesús Polo
Hi Paul
Thanks a lot for your help. Here is the .sam file
Jesus
Jesus
