pvwattsv8 is not working in c#
- Asif K
22 Jul 2024 06:40 #13334
by Asif K
pvwattsv8 is not working in c# was created by Asif K
Hi
I am using C-sharp to develop a code for pvwattsv8.
Interestingly, Modules pvwatts8 executes but without calculating any Power. Irradiance Data is being processed by the SAM Module pvwattsv8, however, it does not generate any Output realted to Power.
For instance, following Output variables are receiving values (there are few other output variable also which are getting values but I am not listing here )ghdndftambwspdsnowalbpoa_monthlysolrad_monthly
However, when it comes to the output variables related to Power like following then all gives 0 valuesolrad_monthlydc_monthlyac_monthlymonthly_energyannual_energy_distribution_timesolrad_annualac_annualac_annual_pre_adjustannual_energycapacity_factorcapacity_factor_ackwh_per_kw
I did many experiments like if there is any missing or wrong input, but I am unsuccessful. Here, very interestingly, when I execute the same code using Module pvwattsv5, then it works fine. Is'nt this Strange!! I tried to find out whats the difference between Input Variables of Modules pvwatts5 and pvwatts8, tried to focus on that but still I am unsuccessful.
I am attaching my c-sharp code herewith, and you may see in line 126 that module pvwatts8 is declared. simple changing this to pvwatts5, it works fine.
22 Jul 2024 17:45 #13338
Replied by Paul Gilman on topic pvwattsv8 is not working in c#
Does the pvwattsv8 module generate a non-zero value for ac_annual when you run it using C# created by SAM's code generator for the default PVWatts / No Financial configuration?
To test that:
1. In SAM create a PVWatts / No Financial case.
2. From the Case menu, click Generate code and choose C# from the list of programming languages.
3. Run the resulting C# program from your coding environment.
If that works, I would recommend using that C# project as a basis for your code.
To test that:
- Asif K
25 Jul 2024 05:16 #13345
by Asif K
Replied by Asif K on topic pvwattsv8 is not working in c#
Hi Paul
Thanks for the quick response.
I am using PVWatts Non-Financial version to generate code c# coding. I think you might have missed my point in last message.
When I rum pvwattv8 simulation module in c# then it reads weather file and process the weather data and generates output like gh, dn, df, aoi, poa, etc.
However, it does not calculate any Power. In other words, my code genrates 0 value for all of the following variables: dc_monthly, ac_monthly, monthly_energy, capacity_factor, capacity_factor_ac, kwh_per_kw
So basically all power related output are zero values.
My same c# code works fime if I uses pvwattsv5 simulation module.
- Asif K
26 Jul 2024 04:38 #13349
by Asif K
Reason Found and problem fixed,
Reason is I was using Weather File from another source. The paramter 'elevaton' was missing or set to null in the my Weather File, which perhaps forced all the calculations inside SAM Module pvwattsv8 to zero, therefore, all power outputs were zero.
Technically, above is ok, but shouldnot pvwattsv8 use a default value of elevation if it is missing in the weather file ? Other SAM modules lile pvwattsv5 works fine without this parameter of elevation.
31 Jul 2024 17:50 #13357
Thanks for the update.
The PV models should check for valid values in the weather file header. The elevation input is required for accurate sun position calculations, so the model should return an error if the input is missing or invalid. We will address this for a future update to SAM and PySAM:
github.com/NREL/ssc/issues/973
