Importing inputs from SAM GUI to PySAM TcsmoltenSalt module
  • Evan
23 May 2024 11:38 #13197 by Evan
Ok thank you, so you're saying there is no way to use the "JSON for Inputs" code generator option in SAM that outputs all variables to a single JSON file, as detailed in the in the "JSON for Inputs" section at the bottom of  nrel-pysam.readthedocs.io/en/main/inputs-from-sam.html ?
Evan
29 May 2024 10:59 - 29 May 2024 11:00 #13218 by Paul Gilman
Hi Evan,
The file generated by the code generator's "JSON for Inputs" option should also work.
Last edit: 29 May 2024 11:00 by Paul Gilman.
  • Evan
29 May 2024 11:51 #13219 by Evan
Would you mind providing some example code on how to load inputs using the single JSON file outputted by the "JSON for Inputs" code generator option?
I think the example JSON for inputs code on the "Importing inputs from SAM" page is incorrect as it is a copy of the code above for the PySAM JSON method which loops through the separate modules even though the text description states "you don’t have to loop through the modules" for the JSON for inputs method.
Evan
  • Ahmed
19 Aug 2024 21:20 #13394 by Ahmed
Hi Evan.
I'm working on a molten salt solar tower.
Can you send me the model?
I hope you can help me with that.
