Battery module: slightly higher input gen values causing wrong output
- Zoltan
13 Sep 2023 04:12 #12499
by Zoltan
Battery module: slightly higher input gen values causing wrong output was created by Zoltan
Attaching the two inputs - they are almost the same, just of the second one the input 'gen' values are a little bit higher (more modules) - but batt_capacity_percent and batt_cycles are totally wrong (zero) in the second case.
Can you please help me with this? Is this a bug?
Thank you!
Zoltán
Thank you!
Zoltán
15 Sep 2023 14:48 #12503
Replied by Paul Gilman on topic Battery module: slightly higher input gen values causing wrong output
Hi Zoltán,
Something is happening after the first 48 hours of operation that causes the battery capacity percent to drop from almost 100% to almost zero. This kind of thing is difficult to troubleshoot without the SAM user interface.
Have you been able to set this up in SAM and get it to work there?
