NREL API error when fetching solar data (PSM v3 TMY)
- Ghazi
25 Mar 2022 11:14 #10728
by Ghazi
NREL API error when fetching solar data (PSM v3 TMY) was created by Ghazi
We're using the NREL API to fetch solar data through pysam. Everything was working nice and well until yesterday when suddenly the NREL API started returning errors with the text "Data processing failure."
The issue started happening at Mar 24,2022 10:16pm UTC and is still ongoing (everything was working fine before that).
pysam version used 2.2.4 (also tested with the latest 3.0.1 and same issue happened).
The error can be reproduced by visiting this url (make sure to set your email and api key)
developer.nrel.gov/api/nsrdb/v2/solar/psm3-tmy-download.csv?names=tmy&wkt=POINT%28-121.46+37.74%29&interval=60&api_key=&email=&utc=false
28 Mar 2022 15:39 #10746
Replied by Paul Gilman on topic NREL API error when fetching solar data (PSM v3 TMY)
Hi Ghazi,
I have received several reports of issues with the NSRDB API in that time period. It seems to be working now in my tests.
Please let me know if you continue to have trouble.
- squables
29 Mar 2022 17:34 #10757
by squables
Replied by squables on topic NREL API error when fetching solar data (PSM v3 TMY)
Had the same issue today on first boot. Fixed by restarting the applicaton. It seems like the app couldn't retrieve the email variable until restart.
30 Mar 2022 17:25 #10773
Thanks for letting us know about this. We are investigating and will fix this for the next update to SAM 2021.12.02 if it is an issue on the SAM end rather than with the API.
- Ghazi
31 Mar 2022 01:10 #10778
by Ghazi
Replied by Ghazi on topic NREL API error when fetching solar data (PSM v3 TMY)
Thanks for the reply Paul.
That is indeed the case, everything is back to normal. The errors stopped shortly after I posted (last one was at Mar 25, 5:40 pm UTC) but, since it was my first post, it needed approval and I wasn't able to reply to it.
