Missing Dynamic Library File when Generating Swift (iOS) Code
- Steven Ledsworth
29 Sep 2021 14:28 #10110
by Steven Ledsworth
Missing Dynamic Library File when Generating Swift (iOS) Code was created by Steven Ledsworth
Hello!
I'm out of my element with using SAM and dynamic languages in general, so this could totally be my mistake, but I'm not seeing the dynamic language file being generated when using the 'generate code' for iOS option in SAM. I get a header file, some csv data files, and the swift bridge file–shouldn't there also be a dynamic library file that contains the implementation of ssc?
I tried grabbing the dylib file directly from the Frameworks folder in the SAM application, but that resulted in an Xcode error stating that the file was built for macOS, not iOS (makes sense). From there I decided to try to build ssc from source, but couldn't even get one of the dependencies built (wxWidgets).
With all that, I'm not sure what the best route is to get PVWatts to work locally on an iOS device. Anyone have any tips or able to point me in the right direction?
Some more details:
macOS 11.6
SAM 2020.11.29
I attached a video of how I am using the SAM application to generate code.
Thanks!
Some more details:
macOS 11.6
SAM 2020.11.29
Thanks!
01 Oct 2021 16:31 #10116
Replied by Paul Gilman on topic Missing Dynamic Library File when Generating Swift (iOS) Code
Hi Steven,
It's been a while since we worked on SAM's code generator for iOS and Android. I fixed a couple of things that should make it work better.
When you run the code generator now, it should now open a web browser with instructions. You can also get to the instructions from the SDK page on the SAM website ( sam.nrel.gov/sdk ) by following the links in the Code Generator section. Here are the URLs for those instructions:
For Android: sam.nrel.gov/11/115
For iOS: sam.nrel.gov/11/116
As mentioned in the instructions, the libraries provided were built from SAM 2017.9.5, so are a bit out of date. You can try your hand at building new ones from the makefiles on GitHub here:
For Android: github.com/NREL/ssc/tree/develop/build_android
For iOS: github.com/NREL/ssc/tree/develop/build_ios
