CoPylot optimization
- mfrasquet
29 May 2021 05:03 #9640
by mfrasquet
CoPylot optimization was created by mfrasquet
Hi!
Is it possible to perform optimizations using CoPylot? I am able to design the solar field using generate_layout() method, and perform simulations using simulate(). But I do not find any method within the API for performing optimizations. Is there any method to do that? Thanks!
03 Jun 2021 18:17 #9660
Replied by Paul Gilman on topic CoPylot optimization
The publication "Demonstrating SolarPILOT's Python API Through Heliostat Optimal Aimpoint Strategy Use Case" by William Hamilton et al. (2021) may be helpful: www.nrel.gov/docs/fy21osti/78774.pdf
You can find other resources here:
github.com/NREL/SolarPILOT
www.nrel.gov/csp/solarpilot.html
- mfrasquet
05 Jun 2021 05:07 #9667
by mfrasquet
Replied by mfrasquet on topic CoPylot optimization
Thanks Paul,
I am already working with CoPylot and yes, William Hamilton et al. (2021) has been very useful, thank you very much. CoPylot.py (available in the github repo) has a list of methods:
Methods
version(p_data: int) -> str
data_create() -> int
data_free(p_data: int) -> bool
api_callback_create(p_data: int) -> None
api_disable_callback(p_data: int) -> None
..... (it continues)
My question was, if among all these methods, there is any with which field optimizations can be performed. I found the necessary methods for field design (i.e. generate_layout) but I cannot find any method for field optimization. Do you know the method for performing field optimziation? Or it is still not implemented?
Thank you very much for your help!
Methods
07 Jun 2021 15:43 #9678
CoPylot does not support optimization methods through the API. This was done by design because Python supports numerous
open-source optimization methods that could be used in conjunction with CoPylot.
