SAM SDK automation using Matlab
- Mohammed Alfailakawi
08 Feb 2021 14:41 #9271
by Mohammed Alfailakawi
SAM SDK automation using Matlab was created by Mohammed Alfailakawi
I am trying to automate a solar power tower (SPT) model in Matlab using the SDK.
My goal is to loop the SPT model multiple times using an array of inputs for some variables, e.g. c_atm_0.
I modified the already existing command based on one single value as follows:
a0= [-0.000558728];
ssccall('data_set_number', data, 'c_atm_0', a0);
To a command which I thought can take an array of values as follows:
a0= [-0.000558728; -0.000347126; -6.89E-05; 4.73E-05];
ssccall('data_set_array', data, 'c_atm_0', a0);
However, I got this message in the Matlab command window:
precheck input: variable 'c_atm_0' (<array>) of wrong type, <number> required.
Can you please help me change this single value based set up in order for the model to accept multiple values.
Thanks in advance.
Mohammed
a0= [-0.000558728];
Thanks in advance.
Mohammed
11 Feb 2021 12:20 #9280
Replied by Paul Gilman on topic SAM SDK automation using Matlab
Hi Mohammed,
In this case, the data type of c_atm_0 is a number, so you can not assign an array value to it.
The following should all work
ssccall('data_set_number', data, 'c_atm_0', -0.000558728);
a0 = -0.000558728;
a0= [-0.000558728; -0.000347126; 6.89E-05; 4.73E-05];
ssccall('data_set_number', data, 'c_atm_0', a0(1));
14 Feb 2021 09:01 #9289
Replied by Mohammed Alfailakawi on topic SAM SDK automation using Matlab
Dear Mr. Gilman,
Thanks a lot for your reply, I really appreciate your help and support.
Thanks for the confirmation, I believe I have a better understanding now.
Thanks a lot.
Mohammed
Thanks a lot.
Mohammed
