Weather data in SAM
- DM
28 May 2020 10:48 #8246
by DM
Weather data in SAM was created by DM
Is there a way where I can consider using intermittent solar data in SAM?
Thank you.
Thank you.
04 Jun 2020 16:25 #8280
Replied by Paul Gilman on topic Weather data in SAM
Hello DM,
SAM's solar models require a complete weather file (one year's worth of hourly or subhourly data), except for the pvwattsv5_1ts SSC module, which simulates a PV system for one time step.
We are working on a version of pvsamv1 that works on a single time step, but it is not yet available.
Otherwise, to run a simulation with weather data for part of a year, you could put the data for the time of interest into the correct rows of an existing weather file and ignore the results for the other time steps. For example, if you have weather data for June 6 through June 25, you could replace the data in the rows for those days, and then ignore results for the other times.
- Matan
09 Jun 2020 17:30 #8291
by Matan
Replied by Matan on topic Weather data in SAM
I very recently built a workaround for this using PySAM! As well as support for leap days (SAM only supports TMY files). Let me know if you want any advice!
10 Jun 2020 10:20 #8296
Thank you Matan!
Just one clarification: SAM only supports weather files that contain one year's worth of data, assuming 8,760 hours per year (so no leap day). While this requirement did originate from the convention used for NREL's original TMY weather files, the data in the file is not required to be typical meteorological year (TMY) data.
- Matan
10 Jun 2020 10:32 #8297
by Matan
Hello Paul,
Yes sorry, of course. Sorry for miss-speaking. Weather files can be Single year or Typical Meteorological Year right? They just do not include Feb 29th!
For my application we are attempting to use SAM on a daily basis to do daily predictions, so the ability to run the SAM simulations on any day of the year is important ( including Feb 29th)! Also I navigated how to run the simulation on a single day of valid weather data ( rather than a full years worth) by appending null data.
Best,
Matan
Best,
Matan
15 Jun 2020 16:07 #8307
Hi Matan,
We are working to make it possible to run pvsamv1 for single time steps which will make it easier to do the kind of analysis you describe. This will be available with the next version of SAM, which we plan to release later this fall:
github.com/NREL/ssc/issues/288
