Suggestions on using irradproc
- Weiming
20 Mar 2020 07:45 #8058
by Weiming
Suggestions on using irradproc was created by Weiming
I'm aware that irradproc is able to convert between GHI, DNI, and DHI given the two of them.
Is there a module to decompose GHI to its two components DNI and DHI?
Thank you
Weiming
Thank you
Weiming
26 Mar 2020 11:19 #8070
Replied by Paul Gilman on topic Suggestions on using irradproc
Hi Weiming,
You might try NREL's DISC model for that application:
www.nrel.gov/grid/solar-resource/disc.html
- Weiming
26 Mar 2020 11:28 #8071
by Weiming
Replied by Weiming on topic Suggestions on using irradproc
Thank you.
I can see that it is embedded in an Excel document. Do you by any chance have this in the SSC module?
Weiming
Weiming
26 Mar 2020 13:19 #8072
Hi Weiming,
It is not available as part of SSC, but here is a version that is part of PVLIB from Sandia National Laboratories:
pvlib-python.readthedocs.io/en/stable/generated/pvlib.irradiance.disc.html
- John
24 Feb 2022 09:04 #10622
by John
Replied by John on topic Suggestions on using irradproc
Hi Paul - Asking via this older but related thread (from a search).
Is there a Python version of the DISC model that you are aware of?
Also - the link to the spreadsheet suggested (in an earlier thread) to get DHI from DNI and GHI (with DNI determined from DISC) is broken. Has this part of getting all three irradiance values been updated. Any chance there is Python code associated with this piece?
Thanks!
John Bleem
Colorado State
Thanks!
John Bleem
Colorado State
24 Feb 2022 16:57 #10624
Hi John,
The PVLIB link above is to a Python library version of the DISC model that converts GHI to DNI.
As for DHI, there are a few models out there. SAM provides the option to choose from the Isotropic, HDKR, or Perez options, which are described in the SAM PV reference manual, available from here: sam.nrel.gov/photovoltaic/pv-publications.html .
