Utilityrate5.ElectricityRates.ur_ec_tou_mat a touple, does not support item assi
- Rob Frohne
24 Feb 2020 01:30 #7997
by Rob Frohne
Utilityrate5.ElectricityRates.ur_ec_tou_mat a touple, does not support item assi was created by Rob Frohne
It is time to go home here, but I thought I'd send you a query, since you are six or more hours ahead of me, and if I wait until tomorrow, it will delay an answer another day.
I'm trying to change the utility rate, and finding it immutable. Maybe I need to use the assign method. Here is what I'm doing:
ur.ElectricityRates.ur_ec_tou_mat[0][4] = rate_sheet.cell_value(i, 1)
I get the following error:
Any ideas?
And thanks!
Rob
TypeError: 'tuple' object does not support item assignment
And thanks!
Rob
24 Feb 2020 15:01 #7998
Replied by Paul Gilman on topic Utilityrate5.ElectricityRates.ur_ec_tou_mat a touple, does not support item assi
Hi Rob,
To assign values as they appear in this screenshot of the energy charge input table in the SAM user interface,
the 'ur_ec_tou_mat' array would be defined as (with line breaks and spacing to make it more legible):
To assign the buy rate for Period 1, Tier 1 to $0.10/kWh, you would set:
So, that part of your assignment looks correct.
From the PySAM 2.0 documentation for the Utilityrate5 module, it looks like 'ur_ec_tou_mat' is a sequence: nrel-pysam.readthedocs.io/en/2.0.2/modules/Utilityrate5.html#module-PySAM.Utilityrate5 .
The error message suggests that `ur.ElectricityRates.ur_ec_tou_mat` is a tuple. Tuples, unlike lists, are immutable in Python, so they can't be changed.
Is that enough information to solve the problem?
ur_ec_tou_mat =
[ 1, 1, 1+38, 0, 0.12, 0 ],
[ 2, 1, 1+38, 0, 0.05, 0 ],
[ 3, 1, 1+38, 0, 0.25, 0 ],
[ 4, 1, 1+38, 0, 0.26, 0 ]
ur_ec_tou_mat[0][4] = 0.1
- Rob Frohne
24 Feb 2020 19:17 #8003
by Rob Frohne
Replied by Rob Frohne on topic Utilityrate5.ElectricityRates.ur_ec_tou_mat a touple, does not support item assi
Thanks Paul,
You and I agree on everything here. You have nicely summarized things. Python does indeed think the type is tuple, and certainly tuples are not mutable.
This is unfortunate, because I need to modify the electric rates to make my rates change over time. I think I have all the code do do that put together now, but I was assuming that the rates were mutable. I'm not really a python programmer (yet), and I'm still stuck. There must be a way around this. Any other ideas?
Rob
type(ur.ElectricityRates.ur_ec_tou_mat)
Out[114]: tuple
Rob
- Rob Frohne
24 Feb 2020 20:45 #8004
by Rob Frohne
I found my answer. You convert the tuple to a list, and then make a new tuple with the values of the list. It seems to work.
Rob
temp_list = [list(x) for x in ur.ElectricityRates.ur_ec_tou_mat]
temp_list[0][4] = rate_sheet.cell_value(i, 1)
temp_list[1][4] = rate_sheet.cell_value(i, 2)
ur.ElectricityRates.ur_ec_tou_mat = tuple(temp_list)
Rob
