SDK for java code generator has an issue
- Kasun
11 Oct 2019 04:48 #7706
by Kasun
SDK for java code generator has an issue was created by Kasun
Exception in thread "main" java.lang.UnsatisfiedLinkError: Can't load library: F:/FYP/Software_Developments/SAM/SSC_SDK_Java_code/SSCAPIJNI.dll
at java.base/java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.base/java.lang.Runtime.load0(Unknown Source)
at java.base/java.lang.System.load(Unknown Source)
at untitled.main(untitled.java:72)
SSCAPIJNI.dll is not in my generated code file. how can i solve that
11 Oct 2019 14:29 #7711
Replied by Paul Gilman on topic SDK for java code generator has an issue
Hi Kasun,
SAM's code generator should create that file. Are you using the SAM code generator as described on the SDK page (see the section toward the bottom of the page)?
sam.nrel.gov/software-development-kit-sdk.html
