Hourly Solar Generation - Multiple Years
- cdavis
18 Mar 2019 14:27 #6703
by cdavis
Hourly Solar Generation - Multiple Years was created by cdavis
If I'm using a weather file spanning multiple years, how can I export the hourly solar generation over this period?
21 Mar 2019 17:04 #6704
Replied by Paul Gilman on topic Hourly Solar Generation - Multiple Years
For now, SAM can only run a simulation on a weather file with one-year's worth of data.
If you are using the SAM SDK, you can run a sequence of one-year simulations to generate output over a multi-year period.
If you are using the SAM desktop application, you could either write an LK script to run the sequence of simulations, or you could manually run a simulation for each weather file.
