unable to access singlediodeparams or singlediode compute modules
- caseyzak24
14 May 2018 16:56 #6242
by caseyzak24
unable to access singlediodeparams or singlediode compute modules was created by caseyzak24
I am using the python SDK to try and run the
and
modules. Below is my code (note that as far as I know it is all properly indented, but I couldn't get the formatting right in this post):
The output is simply:
Based on the fact that no additional info is provided with the error (not the case for other compute modules), it seems to me that the
string is not being recognized by the
method call. I have even checked the ssc source code to ensure that these compute modules aren't referred to by different names. I also confirmed that the irradproc module works fine with the same setup/environment. These single diode modules work fine using the SDKtool on my machine. I am running OSX on a Mac laptop.
This is likely just a stupid coding error but any help is greatly appreciated.
singlediode
singlediodeparams
irr_value_goal = list(range(25,1025,25))
singlediodecurve25 = {'irr':irr_value_goal,'Imp':[],'Vmp':[],'I_sc':[],'V_oc':[],'Pmp':[],'All_V':[],'All_I':[]}
ssc = PySSC()
# ssc.module_exec_set_print(0)
#create the data container where everthing gets carried around
data1 = ssc.data_create()
ssc.data_set_number(data1,b'alpha_isc',0.0007)
ssc.data_set_number(data1,b'adj_ref',-3.86179)
ssc.data_set_number(data1,b'a_ref',2.97911)
ssc.data_set_number(data1, b'Il_ref', 1.8409)
ssc.data_set_number(data1, b'Io_ref', 2.48981e-13)
ssc.data_set_number(data1, b'Rs_ref', 4.96815)
ssc.data_set_number(data1, b'Rsh_ref', 833.884)
ssc.data_set_number(data1, b'T', 25)
ssc.data_set_number(data1, b'I', 1000)
####RUN THE SIMULATION####
module = ssc.module_create(b'singlediodeparams')
if ssc.module_exec(module, data1) == 0:
print('singlediodeparams simulation error')
idx = 1
msg = ssc.module_log(module, 0)
while (msg != None):
print(' : ' + msg.decode("utf - 8"))
msg = ssc.module_log(module, idx)
idx = idx + 1
SystemExit( "Simulation Error" )
a = ssc.data_get_number(data1, b'a')
il = ssc.data_get_number(data1, b'il')
io = ssc.data_get_number(data1, b'io')
rs = ssc.data_get_number(data1, b'rs')
rsh = ssc.data_get_number(data1, b'rsh')
singlediodeparams
module_create()
