Running irradproc submodule with PySSC
- caseyzak24
09 Mar 2018 14:22 #6107
by caseyzak24
Running irradproc submodule with PySSC was created by caseyzak24
I am attempting to use the
module and the
wrapper to calculate sun zenith angle. Here is my Python code:
I get the following error:
I am not sure if the error is because PySSC is setup to only run the
and PySSC is asking for something that ssc doesn't have in this case or if this is an error internal to the compiled ssc libraries. OR, perhaps I am just using the submodule wrong.
Any help with this issue would be greatly appreciated.
irradproc
PySSC
sp=SolarProject()
ssc = PySSC()
ssc.module_exec_set_print(0)
#create the data container where everthing gets carried around
wfd = ssc.data_create()
ssc.data_set_array(wfd,b'beam',[0]*8760)
ssc.data_set_array(wfd,b'diffuse',[0]*8760)
ssc.data_set_number(wfd, b'lat', sp._lat)
ssc.data_set_number(wfd, b'lon', sp._lon)
ssc.data_set_number(wfd, b'tz', sp._tz)
ssc.data_set_array(wfd, b'year', sp._year.tolist())
ssc.data_set_array(wfd, b'month', sp._month.tolist())
ssc.data_set_array(wfd, b'day', sp._day.tolist())
ssc.data_set_array(wfd, b'hour', sp._hour.tolist())
ssc.data_set_array(wfd, b'minute', sp._minute.tolist())
ssc.data_set_number(wfd, b'azimuth', sp.azimuth)
ssc.data_set_number(wfd, b'track_mode', 1)
####RUN THE SIMULATION####
module = ssc.module_create(b'irradproc')
if ssc.module_exec(module, wfd) == 0:
print('irradproc simulation error')
idx = 1
msg = ssc.module_log(module, 0)
while (msg != None):
print(' : ' + msg.decode("utf - 8"))
msg = ssc.module_log(module, idx)
idx = idx + 1
SystemExit( "Simulation Error" );
ssc.module_free(module)
#Check the desired output
np.array(ssc.data_get_array(wfd, b'sun_zen'))[:100]
: ssc variable does not exist: 'global'
pvsamv1
- Angus King
11 Mar 2018 09:12 #6108
by Angus King
Replied by Angus King on topic Running irradproc submodule with PySSC
Casey
See my response to your post on the SAM forum -> sam.nrel.gov/comment/8563#comment-8563
Kind regards
Angus
Kind regards
Angus
