Input variables of SSC tcstrough_physical
- liub06
05 May 2017 02:06 #5433
by liub06
Input variables of SSC tcstrough_physical was created by liub06
I have a question about the input variables in tcstrough_physical SSC.
1. 'hx_config',is there any explanation for the number represent for heat exchanger type. Like '0' represent for shell-tube heat exchanger.
2. If I have already selected the fluid number, such as 3 represent for VP-1 as field HTF and 0 represent for Hitec Solar Salt as storage fluid, do I still fill the inputs of 'field_fl_props' and 'store_fl_props'?
3. Any recommend for inputs 'dt_hot' and 'dt_cold'. I filled 5 and 5 for a 100MW CSP with 7h of TES and the simulation show as followed:
tcstrough_physical errors:
time 0.00 { Controller 3 }:
Heat exchanger sizing failed
unit 3 (Controller) type 'sam_mw_trough_type251' failed at initialization
exec fail(tcstrough_physical): there was a problem simulating in tcskernel(physical trough)
I have already try different 'dt_hot' and 'dt_cold' and examined other inputs. It doesn't work.
Looking forward for your reply and thanks for all your help.
- liub06
08 May 2017 20:09 #5434
by liub06
Replied by liub06 on topic Input variables of SSC tcstrough_physical
I have already solved the problem I posted before based on your previous reply to other reseachers. sam.nrel.gov/node/74713
Thanks for your hard work.
Best wishes!
Bing
Best wishes!
Bing
09 May 2017 11:22 #5435
Replied by Paul Gilman on topic Input variables of SSC tcstrough_physical
Dear Bing,
Thank you for letting me know.
