SSC Guide Missing From SDK
- mark.mendez
31 Mar 2017 12:08 #5299
by mark.mendez
SSC Guide Missing From SDK was created by mark.mendez
Recently I downloaded the SAM SDK, v.2.17r2.
The SSC_Guide PDF is missing from this download. Is there an alternate location where I can download the guide directly? I've attached an image of the unzipped download for reference. Also, I the PDF is not present in the unzipped files.
- mark.mendez
31 Mar 2017 12:16 #5300
by mark.mendez
Replied by mark.mendez on topic SSC Guide Missing From SDK
For others who may have this issue, I downloaded the 2016.3.14 SDK and this download did contain the SSC_guide PDF.
The differences can most likely be seen the in release notes. I'll be using this at a risk until the newest SSC_guide is available.
04 Apr 2017 12:30 #5301
Replied by Paul Gilman on topic SSC Guide Missing From SDK
Dear Mark,
Thank you for pointing out the omission. I've added the SSC and LK guides to the SDK 2017.1.17 package.
The only difference between the current SSC guide and those from previous versions is a new short section describing the Code Generator feature in SAM.
