Change Module Type
- Tom Hardy
05 Jan 2017 11:06 #5063
by Tom Hardy
Change Module Type was created by Tom Hardy
According to the manual in PVWatts V5, there are three options for module type: 1) Standard; 2) Premium; and 3) Thin film
If in this example ( nsrdb.nrel.gov/api-instructions ) we would like to change the module type from Standard to Premium, the manual says to write it like:
#ssc.data_set_number(dat, 'module_type', Premium)
Yet, when I add the former line when specifying the system configuration, the programs gives an error.
Thus, what should be the right way to specify a module type other than Standard?
05 Jan 2017 11:21 #5064
Replied by Paul Gilman on topic Change Module Type
Dear Tom,
The
input variable for the pvwattsv5 module is a number, so you should assign it a value as follows (these examples are in Python, where the hash symbol (#) indicates a comment):
The
module_type
# Standard (UPDATED 1/11/2017)
ssc.data_set_number(dat, 'module_type', 0)
# Premium (UPDATED 1/11/2017)
ssc.data_set_number(dat, 'module_type', 1)
# Thin film
ssc.data_set_number(dat, 'module_type', 2)
- Tom Hardy
11 Jan 2017 01:28 #5065
by Tom Hardy
Replied by Tom Hardy on topic Change Module Type
I believe that for pvwattsv5 the module type values are, instead, as follows:
# Standard
# Premium
# Thin film
Regards
# Standard
# Premium
# Thin film
Regards
11 Jan 2017 12:41 #5066
Hi Tom,
Yes, you are correct. The order in the array is the same as the order in the SAM user interface.
Sorry for my mistake.
