API Instructions - Change of units
- Tom Hardy
05 Jan 2017 10:57 #5059
by Tom Hardy
API Instructions - Change of units was created by Tom Hardy
In API instructions /2. SAM Simulation (
nsrdb.nrel.gov/api-instructions
) it says:
# Specify the system Configuration
# Set system capacity in MW
system_capacity = 4
I the SDK documentation and the PVWatts Version 5 Manual the system size/capacity used as an example is 4 kW.
Shouldn't be here kW instead of MW?
system_capacity = 4
05 Jan 2017 13:00 #5060
Replied by Paul Gilman on topic API Instructions - Change of units
Dear Tom,
Yes. The units for the pvwattsv5 module input variable
are DC kW.
That looks like a typo in the comment of NSRDB example code.
system_capacity
- Tom Hardy
06 Jan 2017 06:48 #5061
by Tom Hardy
Replied by Tom Hardy on topic API Instructions - Change of units
You may also check in ( nsrdb.nrel.gov/api-instructions ) the specifications for the array type. For pvwattsv5, as in the example, I believe that instead of:
# Specify fixed tilt system (1=true, 0=false)
ssc.data_set_number(dat, 'array_type', 0)
Should be:
# Specify array type (0,1,2,3,4) = (Fixed OR, Fixed Roof, 1Axis, Backtracked, 2Axis)
Should be:
10 Jan 2017 13:31 #5062
Dear Tom,
Thank you for that feedback. You are correct that in pvwattsv5, the valid values for array type are 0, 1, 2, 3, or 4. That mistake is in the comment, so should not affect the result.
I will share your comment with the NSRDB team.
