Battery Storage Computed Inputs
28 Oct 2016 15:29 #4856
Replied by Paul Gilman on topic Battery Storage Computed Inputs
Hi Tane,
the INOUT variables are passed from other modules to the battery module and are not modified by the battery module:
hourly_energy is the AC output of the PV system
e_load is the building's AC load
- tmartin
30 Oct 2016 18:16 #4857
by tmartin
Replied by tmartin on topic Battery Storage Computed Inputs
Ok thanks Paul. I was under the impression that INOUTs were variables that were passed into the module, altered, and then passed back out.
If one were to pass the DC output of the system into hourly_energy, would that effectively result in the battery being on the DC bus? Or is the module built in such a way that AC output is the only valid input?
Tane
Tane
31 Oct 2016 16:27 #4858
Hi Tane,
In SSC Version 160, SAM applies the AC to DC conversion efficiency value to the hourly_energy value, so if you set that value to 100%, it would effectively be treated as DC energy.
Note that the AC to DC conversion input is intended to account for electrical losses in the charge controller in addition to rectification from AC to DC, so you might set the value to something lower than 100%.
However, the model still adds battery power on the AC side of the PV inverter, so you cannot use this approach in a system designed to use the battery to increase the DC/AC ratio.
