Help needed with tcsmolten_salt Version 159
- Angus King
03 Jun 2016 02:00 #4482
by Angus King
Help needed with tcsmolten_salt Version 159 was created by Angus King
I'm attempting to use tcsmolten_salt with SDK Version 159 (2016.3.14) but am encountering a problem. I used the Inputs from SAM to create a set of SDK input variables but I must have something wrong. SAM gives a CF of around 0.42 but SDK execution gives -2. I've attached an LK Script and the input weather file. Any help appreciated. Thanks.
Angus
PS: Minor bug: It seem that even with is_dispatch=0, the is_dispatch=1 variables are required
Angus
03 Jun 2016 12:57 #4483
Replied by Paul Gilman on topic Help needed with tcsmolten_salt Version 159
Hi Angus,
The LK file generated by my copy of SAM 2016.3.14 looks very different from the LK script you attached above. There are a bunch of variables missing from your script, although it does run in my copy of SDKtool and generates the same -2 capacity factor that you see.
Could you try generating the LK script again from SAM (shift-F5)? Please double-check that you are using the latest version of SAM. To see the version number, click Help and then in the Help window, click About. SAM's SSC version number should match the one that is loaded in SDKtool.
Here is a link to the LK script I generated . If you have a way to do a text compare, you'll quickly see the difference between the two files.
- Angus King
03 Jun 2016 19:47 #4484
by Angus King
Replied by Angus King on topic Help needed with tcsmolten_salt Version 159
Paul
Thanks once again. Your script produces useful results. The one I created was minimalist with just those variables I felt I needed from the REQUIRE column - values of . I'll now compare and find my problem.
Kind regards
Angus
Kind regards
Angus
- Angus King
03 Jun 2016 19:53 #4485
by Angus King
Paul
And I'll try and remember Shift-F5
- Angus King
03 Jun 2016 20:54 #4486
by Angus King
Paul
Sheepishly, I had a problem with 'Turbine output fraction' set at 0 rather than 1.
var ('f_turb_tou_periods', [1, 1, 1, 1, 1, 1, 1, 1, 1]); works better than var ('f_turb_tou_periods', [0, 0, 0, 0, 0, 0, 0, 0, 0]);
Kind regards
Angus
Kind regards
Angus
