Problem loading solar resource file
- jesusm1985
01 Jun 2016 20:14 #4470
by jesusm1985
Problem loading solar resource file was created by jesusm1985
Hi, I'm trying to execute the Matlab example given in the SDK files (pvwatts.m). However, I'm getting this error:
precheck input: variable 'solar_resource_file' required but not assigned
I have not changed the original file.
Can someone give me a clue about how to solve the problem?
I appreciate any comment. Thank you in advance
- Angus King
01 Jun 2016 21:13 #4471
by Angus King
Replied by Angus King on topic Problem loading solar resource file
jesus
Line 13 should (probably) be "... data, 'solar_resource_file', ..." rather than "... data, 'file_name', ..."
Angus
Angus
- jesusm1985
01 Jun 2016 22:03 #4472
by jesusm1985
Replied by jesusm1985 on topic Problem loading solar resource file
Thank you Angus, it works!
Is there any file that I can read to know all this kind of details?
- Angus King
02 Jun 2016 00:52 #4473
by Angus King
If you go to your SAM SDK Library there's a program sdktool.exe Execute that and select the desired model on the left to show all it's variables. This is described in the ssc_guide (page 27 of the current copy)
Angus
Angus
- jesusm1985
02 Jun 2016 16:24 #4474
by jesusm1985
Excellent, thank you very much Angus.
