Diffuse Shade Loss Parameter for SDK
18 Nov 2016 16:42 #4215
Replied by Paul Gilman on topic Diffuse Shade Loss Parameter for SDK
Hi Stephen (and James),
This discussion may be a bit misleading.
The self-shading model is part of pvsamv1, so you can access it via the SDK. Use the
input to enable it: A value of 1 is for the non-linear option for modules with crystalline silicon cells, and 2 is for the linear option for thin-film modules. The model will calculate self-shading losses based on the subarray
inputs, along with the module area.
The self-shading model's non-linear option for crystalline silicon modules does account for the effect of self shading on both the incident beam and diffuse irradiance. The linear option only calculates a reduction in beam irradiance, based on the assumption that thin-film modules are affected less by the reduction in diffuse irradiance than are crystalline silicon modules.
My comments about the shading scene above are about shading of the array by nearby objects, which requires a 3D representation of the array and objects around the array which may cause shadows, which is not part of pvsamv1.
subarray[<em>n</em>]_shade_mode
nmodx
nmody
rotlim
gcr
tilt
azimuth
- Stephen Peters
22 Nov 2016 09:57 #4216
by Stephen Peters
Replied by Stephen Peters on topic Diffuse Shade Loss Parameter for SDK
Thanks for clearing that up! I have a few more questions but will start another thread.
cheers,
Stephen
cheers,
Stephen
