Modeling Gas Turbine Pant with Particle Solar Receiver
  • William Rodriguez
28 Mar 2016 16:44 #4206 by William Rodriguez
Using SAM,
Can I model a gas turbine plant including a solar central receiver, wherein the solar central receiver further heats up the compressed air discharged from the compressor before being used in the combustor of the gas turbine plant?
Basically, what I want to model is the Sun Shot Project “a small particle solar receiver for high temperature Brayton Power Cycles”
www1.eere.energy.gov/solar/pdfs/55459.pdf
Any help/ideas will be highly appreciated. Thank you.
William
